Guys im gonna be running down the 1.4 at WSID this wednesday.
Any tips?..
Never driven a full drift setip car on a 1.4 mile run b4. So dont know what to expect. Any guesses on my time?.
Specs:
Weight: 1400 kg inc my skinny azzz
Power: 170 rwkw approxx
Wheels: 17x9 and 17x8.5 (some german brand on em atm)
Im hoping for a 14 sec pass.. Low 14's
https://www.sau.com.au/forums/topic/50949-cefiro-14-mile-time/
I got a 14.56 @ 98mph, or there abouts. That was with the old tyres that were on the car from japan, and wheel spin city. But my advice would be let the tyre pressure down. Another mate gained about 0.5sec from pretty much tyre pressure alone.
Even if you dont get a good run, look at the mph, its a better indicator.
From previous attempts (on closed reads :wassup: ) to get the car going from stationary it does spin its nuts off and that was launching at 3000 revs.
But beacuse of the stiff coilovers the car seems to do a jumping jack flash at the rears all over the place. Hmm. Ill do the usual let the tyres out and so forth but dont know much about the stiff suspension?..
launching on a road and a track are completely different.
when you launch u should launch using ur handbrake... also dont flat ur foot... hold to about 3k and let the clutch out.... dont dump it... feather the throttle so ur backing off just a little when its spinning to gain traction and then balance it with more revs etc and once u have enough traction put the foot into its arse and change ur gears as quick as possible :D
OK Boyz.. I did a 14.2 my best time.. with spare tyre in the back + subs woofer, bad launches, Faulty gearbox (all gears hard to get into and crunching) and speakers etc.. pretty much street trim on the car..
Should have been a high 13's but oh wellz... its a drift car afterwall not a drag car. :wassup:
LOL Will post up my sheet soon and a vid of me running it.
here is my time slip. Damn it with the speed i was carrying i should have been a high 13's for sure. What u guys reckon. becuase due to meggala he said that at 98mph would have been a low 14's. But at 100.88 on mine would have been at least a 13.9 or lower. :)
My rection and 60 foot timed sucked. LOL .. not bad for a first go btw. So what u guys reckon.
Im still trying to upload the vid onto sau.
the guy next to me was a vl commhore.. Absolute sleeper. It looked like a stock vl.. with bad panels and paint etc. Only found out what he had under the hood when he pulled away from me after 2rd gear. rb25 block with bigger turbo i found out later on. LOL. :thumbsup:
I was mugged i tell ya.. hahaha
meh thats not that bad for the time :thumbsup:
Dr_Drift ran a 14.05 in my R32 with 142.5rwkw @ 93MPH
shows what a launch can do for ur times :)
The soarer ran a 13.8 @ 102MPH but thats a much heavier car and an auto...
it only had 154rwkw
Damn commodores with Nissan engines in them. :thumbsup: At least you know you got done by an import engine though :)
I think perhaps we are all a little jaded now with the 10 sec factor. A 14 sec time and low at that is good. I'd be lucky if my A31 ran a 20 second pass *chuckle*
My mates call VL's "poor man's skylines" lol!
and i totally agree with your "10 second factor comment"...
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
