i have a cat back zorst, but its time to get a hi flow cat and front pipe.
problem is i have had offers ranging from $660 to $850 bucks.
really all im chasing is more power, and thats about it.
is there anywhere you guys can recommend in perth who will look after me and not do a botchy job?
i hear i need an extended branch pipe too, is that a standard fixture?
and what is the point of a screamer pipe and roughly the costs involved?
(r33 gtst) :aroused:
https://www.sau.com.au/forums/topic/51600-time-for-a-front-pipe/
i have a single pipe and it works fine.... :D
anyone had a chance to compare a dual pipe to a single pipe?
some people have told me that duels arnt better because of the turbulance created as the 2nd pipe connects back up, but they could be talking from their ass.... can anyone settle this arguement? :P
