After owning a couple of imports now I've come to realise that some parts etc may be hard or expensive to get. Here's a couple of little jobs some of you might want to do in the near future.
ELECTRIC AERIAL
My silvia had a horrible grinding noise when using the electric aerial. I've seen a lot of silvias and a few skylines where they've had to replace the aerial for a cheaper piece of junk.
One day mine just stopped half way down and I decided to have a go at pulling it apart and clean/lubricate it if possible- it took a couple of hours and when finished it worked like new. I used diesel and detergent to clean everything once apart and a white silicon based electrical lubricant when re-assembling. The workings inside were filthy with that black stuff you see in the engine bays etc - this clogged-up everything.
Skylines look like they've got the same aerial - my r33 hasn't given any problems yet but I'll probably do it one day.
HEATER HOSES
On the silvia I had one blow and after spending weeks clocking up a phone bill looking for new ones ( couldn't find anyone in QLD back then) I pulled the whole lot off and went to repco to see if anything matched. The ones around the back matched with VN commodore and Camira parts exactly - and only cost about 20 dollars!
CAMSHAFT BELT IDLER PULLEYS
Did the cam belt in the '33 and got some pretty wild prices from nissan for the idlers - ended up going to a company which specialises in bearings - they took the numbers and had the parts overnight.
I saved around 200 dollars here - it gives you a feeling of satisfaction when you get a big saving after doing the job yourself and hunt around a bit!
Anyway hope this helps a bit if anyone's mucking around doing these jobs - it all helps!
I'd be interested in any other helpful tips from other owners so post away if you like!
https://www.sau.com.au/forums/topic/51857-fiddly-stuff/
Yeah, You can get cam belts to suit the r33 from aftermarket suppliers.
E.g. Anyone who stocks Gates belts and Hoses
And bearings? well I haven't seen the idler for the 33, but I assume you would only have to press a bearing out and press a new one in? Any bearing stockist usually have a good range of NSK.
Cheers
Sumo
https://www.sau.com.au/forums/topic/51857-fiddly-stuff/#findComment-1025503
Tensioner NSK 60TB0683 EA7L 806
Idler NSK 56TB2801B01 ENSL 309
Hey fellas
My dad and I looked into pressing out the bearings and putting in new ones but it looked like you'd have to be really skillfull not to wreck the whole thing. A bloke in Gympie QLD who's got all the right gear did it and the bearing lasted about a week and we all know what the bad outcome of a seized tensioner would be.
So we just bought the parts.The price was about a third of genuine so we were happy.
Another little blunder we ran into was the WATERPUMP. Dad's rb20's pump had a hernia and a VL one fit perfectly but on my '33 a bolt hole is different so you'd have to drill and tap a hole to suit or just buy the expensive r33 pump. Apparently on some 25's the VL pump fits but on mine it didn't. My car has only done 80000 so I'll leave it a bit longer.
That timing belt price is excellent. Where from??? Dad just paid over 100 bucks for one as he couldn't source one cheaper.
https://www.sau.com.au/forums/topic/51857-fiddly-stuff/#findComment-1025767
  • 1 month later...
RTHIRTY3
Got the parts from the local bearing shop which deals with anything from excavator, chainsaw or car parts/bearings.
Any local bearing parts dealer which deals with NSK bearings should be fine.
Don't exactly know the name of the store - if you really want it I can email my dad.
The bloke can send stuff by mail.
The prices were around $56 for the idler and $76 for the tensioner - once again if you want to know exactly I can email my dad.
It saved me a lot - genuine was really expensive.
No problem at all with the parts - sit them next to the factory ones and they look exactly the same.
Dad's rb20 has got idler/tensioner from the same place too and it does a lot of miles.
https://www.sau.com.au/forums/topic/51857-fiddly-stuff/#findComment-1075307
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
