Some of you may or may not know I have had some misfire problems.
My 32GTR would miss badly on load.
After a few weeks I sourced some new coils, and this solved most of the problems.
Until this time I had been running new OWS iridium plugs.
I tried (and have fixed) the very minor missing problem with changing back to coppers, but when I removed the OWS plugs (only 1000 kays), the electrode and tip were clean, but the plug seat (where it screws into the head) was wet on #2 and #3. The rest were dry.
Is this a problem?
I noticed the plugs were not completely tight - would this cause it?
Or driving around with dodgy coils fouling the plugs, then when new coils went in the tips and electrodes cleaned up - i.e. wetness left over from misfiring?
Any ideas? Thanks
https://www.sau.com.au/forums/topic/51929-concerned-oil-or-fuel-around-plugs/
G'day Ronin 09
we have had wet plugs a few times in my car, missfiring also. Went through 5 to 6 sets of plugs before finding the correct type and gap. (they would always get fouled up). Last time I had the problem car wouldnt even start, found that the plugs were wet with fuel. Now I have correct plugs and gaps and new coils and havent had problem since.
Just my thoughts anyway. Cheers
Hi Stacey,
Thanks for that info... I have my plugs gapped at 0.8 (it was missing at any larger gap) and the car actually doesn't like starting all the time - needs alot of cranking to turn over.
In your situation, wouldn't all the plugs be wet? Only #2 and #3 are in my case. I am going to pull them out now and check them out again
Thanks heaps
oil fouling (wet) usually means that oil is getting into the combustion chamber.
They have oil on the electrode and tip, but you said that the electrode and tip were clean so im not to sure where the oil is coming from.
Oil fouled plugs make an engine missfire bad which is a symtom you have.
Check for worn piston rings, valve stem seals and valve guides.
I dont it would be fuel because it leaves dry carbon on the tip and electrode.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
