You haven't seem me leading a cruise then have ya?  :)
Strutto JR2: Chuck a skid dad and do one better than that last one.
strutto: *smiles* wheels light up and the back end of the car comes out then suddenly snaps back. At precisley the same moment the cars rear end snaps back strutto hears a thump from the back seat. He turns around to see Strutto Jr2 rubbing his head.
Strutto: are you alright?
Strutto Jr2: That was cool dad.
Disclaimer: this story may or may not be true.
https://www.sau.com.au/forums/topic/52481-beware/#findComment-1035565
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
    • Good on you for mentioning, that helps as far as other things you might need to check
