Hi
Has anyone got the nismo 740cc injectors running off an Apexi PFC and found any problems with idle or take off?
I have a 1996 gts-t and I'm currently looking at upgrading my injectors to allow enough boost to get to 250rwkw and I have spoken to a few workshops who believe I may get some small problems with injectors that are too large for the application (550cc whould be plenty).
I was thinking of getting these from Nengun, which list them for about $940 plus $50 delivery, but can anyone who has ordered these from Nengun let me know what additional costs such as duties and taxes they paid so i can get a clear idea of final costs?
I currently have all the other support systems PFC, FMIC, Turbo, pump.....etc
I was also adivsed to get a new stock or adjustable fuel pressure regulator as the one on the car is now 8 years old and running at stock boost (6psi?) most of its life and may cause a point of weakness in the system, so for about $150 its cheap insurance. Has any had a stock FPR fail?
Cheers guys
https://www.sau.com.au/forums/topic/52619-nismo-740cc-injectors/
i paid the same, delivered from nengun. Nothing more to pay like tax or anything.
with my PFC, the Nismo 740cc's were no problem at all.
My car runs smooth, idles smooth. You wouldnt even know its got 740's in it.
Im still using my stock fuel reg with no problems. No need to spend $$$ on an aftermarket one
boost has nothing to do with it. Its how much fuel you need for the given airflow.
but i was running 16psi taking it to 7500rpm, which will turn into 20psi once i get a bigger (again) fuel pump, and my turbo back on the car
which turbo u running that needs 20psi to make 250rwkw?
Gigolo,
If your car is running ok now then your FPR is fine.Any good mechanic will do a run with a fuel pressure gauge whilst on the dyno checking your readings regardless.
As for the 740cc thats a huge over kill for 250rwkw but that’s fine it’s good if you plan to go further in the future anyway.
As for idling problems there’s no way if your tuner has a clue you should experience any issues with these size injectors and at a sensible base fuel pressure.
BR,
JH
Hi
Cheers guys
As I understand it, the fuel pressure rises with the ammount of boost pressure, but the injector duty cycle varies with airflow (AFM/ECU).
I have a T3/4 with unknown specs, but makes 215rwkw at 13psi. 20 psi was just an estimate to get 250rwkw at 7000rpm.
I was advised to get a the FPR by Jim at CRD - even a new stock one, as he has seen some of the stock ones fail if they are not always up to the job. Also makes easier to get the tune spot. So for 150 it may save a 4000 rebuild
you'll know if its failed right off the bat. The car will just run rich as, thats what mine did and blew a huge fuel-cloud out the rear end when on boost.
save yourself some $$$ and buy one when you actually need one. Not before.
Generally if your FPR fails you will be over fueled to the point you will have black smoke pouring out the back.
So the whole rebuild thing is ass.
Your injector duty cycles have nothing to do with that at all bascially 10.5 - 12ms (depends on ECU) is max injector duty before there fully opened so the ratio is worked out depending on where your tune is at that point!
IE: (EXAMPLE)
18psi - 6500rpm - 80% load = 6.5ms so therefore your around 60% IDC offuisly the ms on the injectors are decided on your AFR where the tuner feels is best.
I think your mechanic is probably saying you can get close to your 250rwkw with standard injectors a fuel pressure reg to up the rail pressure and some more boost.
You can make 10million HP theres no extra load on your FPR. :)
BR,
JH
Well just off topic slightly, I have purchased some Nismo 740cc injectors for my R33, I am yet to see them yet.. I am wondering when the bloody hell they would be sent. Anyone dealt with Nengun before? how long does it normally take to get stock from them? I can't even track via EMS yet. If anyone has dealt with them let me know please how it went?
Once I get them (hopefully soon) I will be installing them onto my R33 running a FMIC and Haltech ECU and Haltech Ignition Systems. Obviously I will be upgrading the pump and fuel rail to suit.
Aridyne!
So a failed FPR will not cause it to lean out and detonate? Because this is what I was told when visiting CRD with my car on the weekend.
Thanks for all the info R31 Nismoid and Japsky33.
If there is no real danger then  i may as well hold off and save some $$$.
It depends how it failed.. quite often I see them not working right, or the pressure pipe has blown or split.. this certainly makes the car lean out.
I can't see it failing and holding more pressure, making the car rich?
4 weeks for mine. that was more Customs fault as it seemed to sit there for a week.
give it a good 4 weeks
Mmm I wish he would hurry up so I can get them to my installer and work out what else I require to get my car running hunky dory... and without fear of hammering the throttle and not killing a injector and then the rest:(
Anyone grabbed a new set of those HKS Cam gears.. the new models that they are trying to sell against the Tomei?
did you have to get injector collars with them at all ?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
