Gday Folks, I attended the cruise and i can only say one thing, what an utter waste of police resources.... sending 5 cars and 6 officers out to Newton to try and defect as many cars as possible (yes they did say that :D ), for over 2 hours. I for one am shocked and amazed at the actions of these officers, and would encourage anyone who came on the cruise to complain in all appropriate channels:
The Police cars in attendance were:
XQD 555
XQD 093
XQD 363
XQE 377
WQX 371
The Officers at the scene were: (only managed to get 1 name, but all numbers)
1964 (did not reveal name when asked politely .... i thought this was legal requirement if asked??)
4690
7244
8812
1817
2159
And the channels for complaint:
SA Police:
[email protected]
Ph: 08 8207 5000
The Australian:
http://www.theaustralian.news.com.au/secti...55ETEXT,00.html
The Advertiser:
http://www.theadvertiser.news.com.au/secti...s^^TEXT,00.html
The ABC:
http://www.abc.net.au/contact/
A Current Affair:
P.O. Box 9
North Adelaide SA 5006
Ph: (08) 8267 0298
http://aca.ninemsn.com.au/storyidea/story_ideas.asp
Today Tonight:
http://seven.com.au/todaytonight/contact_suggest
Again, Feel free to bombard the appropriate channels with complaints/suggestions.... practice your right to free speech!
This is also going up on Ausrotary, Toymods, and Nissansilvia.com, so feel free to put it up on any other forum you think of
Cheers
Robbo
https://www.sau.com.au/forums/topic/52791-cruise-oct-8th/#findComment-1043286
Yeah, its no good..... :D Lucky i wasn't driving... was with a mate in an r31 and another in a soarer, they didn't get done, but i saw numerous imports receive a defect and overheard one officer accuse the owner of a (from what i could see) stock r33 gtr of doing 'burnouts'.... even after he explained that it would be hard to do in a 4wd car :)
ridiculous, simply ridiculous and completely unjustified is all i can say... i really do hope a lot of people put in some complaints...
https://www.sau.com.au/forums/topic/52791-cruise-oct-8th/#findComment-1043293
yeah I didn't get done - the officer was quite polite to me and told me I had a really nice car :D
Total waste of resources though - I hope everyone writes an email to the approriate people - I know I will!
https://www.sau.com.au/forums/topic/52791-cruise-oct-8th/#findComment-1043483
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
