HI guys :D
i've been looking for this thread, but it seems that it doesnt even exsist!
all car forumes has one -if not a few- threads about it, so i thought we should give it a go..
please every one chip in.. starting with the FREE waight reduction...
keep in mind that most of us aren't welling to go extreme (like ditching the AC, stereo,..etc) so keep it streetable! :burnout:
https://www.sau.com.au/forums/topic/53116-waight-reduction/
there is an old thread with the weight of most of the components for an r33.. http://www.skylinesaustralia.com/forums/sh...ead.php?t=28670
realistically though you may save 100-150kg.. but it would make the car very primitive for day to day driving... and most of the time you can upgrade the power to overcome the weight (again been discussed in other threads)
i ripped out most of the interior of my old shitter r31 a few weeks ago, but the noise levels were too annoying and it didn't feel any noticeable quicker so i put it all back in :)
if you want to spend $1000's saving 20-30kg here, another 10kg there on CF, go for it.. I'd rather spend the money on upping the power and/or handling and keeping a nice car, than worrying about it too much unless it was an exclusive or 90% track car.
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043812
there's not a whole lot u can do for free unless u want to take seats and trims out, get a bar to lock out the hicas, saves aboutr 20kgs i think
if u wanted to go crazy then u could go cutting things, but then it wouldn't be street legal anymore
is there a step by step guide on removing hicas ??
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043846
also, my heater is desconnected..
-since am going to need it when hell freezes over!:)-
so should i go ahead and remove the whole darn thing?? is it easy? and how much waight do you think it is...
what about the engine bay?? nothing to get rid off over there??
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043851
how do u mean the heater iis disconnected? isn't it all one system?
u could take the reinforcements off the front and rear bars, but wouldn't recommend as would minimise crash zone, don't think theres much in the engine bay, but i agree with predator, power is so easy in skylines y not just buy go fast bits
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043870
for some fun, strip the tar out, about 15-20kg around the car there
and of course the air con with its compressor, receiver/collector, heat exchanger. Heater core in the dash as well if you are kken.
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043928
replace non critical bolts and nuts with alloy or alluminium one's. Any bolts which protrude from the nut can be cut down. remove the tar from under the floor pan (may induce rust)...
Brackets like the one that holds the Fuel Vapor canaster can be modified. there over kill. Look around under the bonnet see what else can be cut down..
Ummm use helium in your tyres :)
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043930
relocate the battery to the boot so theres more weight over rear wheels. your not losing the weight but at lest it's more useful their. prob no point in a gtr being 4wd.
And no point in a R33 or R34 because the battery is already in the boot. Yes, Japanese cars are always superior :)
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043986
lol! Like any of our cars are street legal by the RTA's rules anyway!!! hahah Seriously, it would probably only have to be about 3% of users on this site which have a skyline which would pretty much have to be stock in Every way to be legal by the RTA's modding rules.
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043989
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
