Originally posted by VISHES
r32?? i thought phil drives an r33 gtr....why would u sell an RZ Supra for an r32 gtr? :)
Yeah he use to drive a R33 GTR with nice gold simmons. It was a nice purple one. I believe he said the R33 GTR was too fat and heavy and not quick enough so he bought the R32 GTR Vspec.
Damn hot car that R32. Damn! Damn Damn.......................... god dman!
  • Replies 133
Originally posted by 400HP
hahah good stuff.  Anyway time to go for a cruise soon. Mona's car is here too so we can get together soon.
Anyway we've hijacked the thread so we'll take it up on ICQ. Linus PM me your ICQ.
Cheers
Yang
i'm up for a cruise, i'm going nasho tonight and probly tomorow if anyones interested,
new wheel alignment, gotta test it out :)
Originally posted by nissanpower
i see your car around too vishes.. the yellow s15
around canley/cabra sometimes
i got a black r33.. but you wouldnt even be able to tell.. cos how many r33s are there around now!
hehehe...true man...the same can be said for all the silvia models..i wonder whats more common on our roads...silvias or skylines?
hey dude.. hehe long time..
hardly post now.. some ppl actually do work at work :(
hows things been? don't think timmy even comes on here no more? haven't seen him post.. anyway if you guys happen to go for a cruise some time soon, count me in, be good to catch up and meet some new ppl.
Originally posted by dazsta
minh, giving me a spin this weekend!! hehehe
my first post in ages, hehe
wheres timmy boy these days and dflash?
Originally posted by SDU4EVA
Very hot R32 Vspec. With Carbon Fibre Bonnet around the Cabra area. Lucky bastard.
At the lights we lined up.Once the lights turned green we both took off like a sling shot.
On First gear he was pulling hard on me by 6 car lengths. By then I knew I couldnt catch him running in my Adidas Climacool so I slowed the pace down and jogged again. :(
I had a nice chat with him Saturday night- that car goes hard!!!
He picked up these 2 russian chicks at a servo when we refueled lol :lol:
hahah this is the worst,
All the cabra/canley ppl have hi jacked this thread hard!!!
hahaha
Well if your intrested in lil ol' me, i drive a Silver sky, around cabra canley area all the time, ffs i went to skool there :P
SDU4EVA maybe you seen my first r33 parked in front of the skool about 2 years ago when i was pissing away my HSC :)
Gun metal grey one,
heheh
Yeh lets got for RUN thru the NASHO!!!
2niTE!!!!
donnie
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
