zippo got found by CEFF1E, what a champion. Plus he let me take his beast for a drive.
Nice.
And yeah I nearly did pull the ****er out I didn't wanna be like the dude who stole your zippo. My cars seem to claim those things like a black hole - glad the cef hasn't got one yet.
sorry guys I couldnt make it, ended up going up the coast on sat arvo.
looks like it was fun.
hope you can do it again soon.
would have been good to see some other cefros on the road.
In regards to the autec kit if somone does it then I too will be interested in grabbing one. I have one at the moment but the rear has a crack in it, so dont know if it will be good for copying.
have a look in the cefiro rides and my car is in there as cefiro, see if you like it and we can possibly arrange something, I want to make sure that I can spray them up, as my paint job is a white with a gold pearl in it so I dont wan to get it and not be ablt to spray them up. I can maybe get the rear bar from, forgotton the name of the other place but see how we go. I want to wait till I get my tax back (should be soon).
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
