AP 6 pot calipers - $2000
HKS 2835R internal gated turbo - $1800
280 deg/ 11.5mm Apexi RB26 cams - $1000
SR20 turbo kit - HKS 2835R turbo, new s/s manifold + dump pipe - $2200
R33 2 door Ganodor mirrors - $500
RB26 cam covers - $300
Polished cam covers - $500
ATS 2 way diff - $1200
HKS 4 way shocks - R33 GT-R - $2000
Q45 air flow meter - $300
RB26 550cc injectors + std rail - $600
RB26 950cc injectors + rail - $900
HKS Twin Power system - $800
Splitfire coils - $650
RB26 Grex valve springs - $350
Std rebuilt RB26 long motor - $5000
Email address is cbaloglow(@)netspace.net.au . Most parts are new, pm or email for pics/more info.
https://www.sau.com.au/forums/topic/53799-a-ton-of-parts/
Two GT-R Trust gearboxes - $10,000
One has been rebuilt to new specs with billet selector forks + center plates, the other is apart.
RB26 twin highmount manifold - $1200
HKS BCNR-33 Drag Shocks - $1500
Brand new still in factory packaging. The R33 shocks have been discontined for a few years, pretty damn hard to find.
https://www.sau.com.au/forums/topic/53799-a-ton-of-parts/#findComment-1054453
  • 1 month later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
