If you are keen to look at a black one in Melbourne, manual, turbo, 45,000kms checkout http://www.skylinesaustralia.com/classifie...php?product=308
you will need more than $30k though :D
https://www.sau.com.au/forums/topic/54220-r34-gtt/#findComment-1074250
hey supra18t, i got a friend who is selling his r34,i was personaly going to buy this car for myself, but i bought another r34 already.
1998 NISSAN SKYLINE R34 25GT-T.
only ever done 48,000 kls
-Full Bomex bodykit with tommy kaira rear spoiler
-Huge custom stainless steel frontmount intercooler
-full custom 3" exhaust system with 7" barrel 5" tip
- HKS air filter
-turbosmart dual stage boost controller,
-Zex Nitrous oxide system with Purge kit(Optional) Apexi B.O.V
-turbo timer
-Sony CD player
.etc...
his also got tommy kaira front bar, i think :dump:
he want 36k
https://www.sau.com.au/forums/topic/54220-r34-gtt/#findComment-1076607
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
