Im in on a group buy if anyone else is interested! Hey YogiOOO, can you get them for $450 all the time?
I was reading a post yesterday (i think) that said they were $550 retail and $350 trade?
I also read in zoom that you can buy reducers with the Magic cat so it can fit on a 3 inch exhaust. Im not sure if i'd like that though.
Shaun.
  • Replies 54
Im certainly not an expert, but i thought it was just a measure of the ability of air to flow thru a given space. And as airflow is proportional to engine hp, the more cfm an exhaust can flow, the more hp it can handle without significant restriction. Does that make sense??
Yeah, the air on the exhaust side would be less dense due to the heat involved. So i suppose you've gotta allow for the expansion of the exhaust gasses. Its not that MORE air is flowing out of the ehaust compared to the inlet because the same amount of air going in has to come out again. Its just that the hotter exhaust gas will want to expand, hence requiring more space to flow through without significant restriction. Thats what i reckon.
Oh, i just spoke to the people that make MAGIC CAT on the Northern Beaches (Sydney), and they have come down in price now to $300 each. I mentioned a group buy and he said that he'd be interested in that. Im not sure what sort of discount though. The cats now neck down from 4 inch to about 3.5 inch apparently. I havent heard anything bad about them, so ill probably get one.
SydneyKid has tested this on one of their race cars.
their race cars don't use cats so a dyno run was done as is and as a test he fitted the 4 inch Magic Cat and dyno'd again and the car lost no power at all.
he mentioned that this was the ONLY cat he had seen with this type of result.
Considering the CATCO 3 inch ones are worth about $250 I think, this magic cat at $300 is a bargain.
Shaun.
i bought that one there at trade, so its was alot cheaper than any price mentioned above. I'm taking mine to get the reducers put on this weekend hopefully for my 3" exhaust
shif_tea: Depends on the suppliers - Some places we can buy all the auto elec stuff at trade price, but if I were to go to buy their 240 volt gear - we get no discount. (I know as we needed fluro lights for the workshop)
I have heard with places like repco, once your setup with an account with them, you have access to their whole range - although im only going on what I have been told.
Cheers
Sumo
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
