  • Replies 91
Ok time again for an updated picture. I have recently had the cam covers and inlet manifold powdercoated, turned out pretty good i think. The black cover in the middle has still only got a cover of primer on it so it'll look a little better in a few days. I have actually cut out the raised nissan emblem that was in the middle of this and filled it over with fiberglass.
The Turbo kit i got i purchased off a fellow forum member, "Steve". It's a HKS 3037 + HKS wastegate but locally made manifold and dump pipe. Think i paid about $4000 for it all including intercooler piping and oil lines.
It was his original forum thread that convinced me that i needed the 3037 and when it came time for me to actually purchase one he was returning his car to stock, so i purchased his complete setup.
Not too much longer i hope, it has taken me 2 years to get to this stage. Just need to find the time to get the engine back in. Both me and my old man have a couple of weeks off over christmas so hopefully i'll get 99% of it done then.
No idea why steve returned his car back to stock, you'll have to ask him he's still on these forums.
  • 3 weeks later...
  • 1 month later...
I've really only got the intercooler piping left to do. I had been waiting the last month for a trust blow off valve to arrive from nengun and that finally arrived this week. On saturday i'll go see what piping/bends etc that i need and hopefully i can find the time in the next couple of weeks to get that made up.
Edited by B33st
  • 1 month later...
Have not had much of a chance to do a whole lot in the past few weeks. The intercooler is mounted and the pipe is all cut to size just need to get it welded up. I also need to get a new hose made up for the air con as it current one fouls on the exhaust manifold.
I'm off to VIC for a couple of weeks from tomorrow (grand prix and fishing trip up the Murray) and then hopefully i can get stuck into the last few things when i get back.
I'll post as soon as some more progress is made.
I went with him as previously i was getting most stuff done by Hardcore at slacks creek and i found out that he was the one that was doing all the headwork / machining for them so pretty much went straight to the source. He's pretty well known in drag racing circles and has been supercomp champion a few times now racing his own cars, you'll see his name across the top of the main stand at willowbank.
HARDCORE "PERFORMANCE"???? *shudder*
Mate, my advise is to stay away from Hardcore, unless you want to buy something like a tacho or a blow off valve. In the few times i've been there where i had a leaking intercooler (which i knew because it was prone to that), and took my car in to fix that and only that. I had a subzero plenum on it, which they tried to tell me the runners werent sealing properly and re-welded without asking, and said it fixed the problem (which it didnt), then got the suprise of having a coke bottle stuck between my intercooler and bumper (which they treid to convince me they didnt put it there), add to that an undone throttle cable which got stuck half open when trying to test to see if my intercooler was fixed, and a fuel rail which wasnt done up and p!ssed fuel everwhere (which they told me it was done up really tight, and must have a problem with the thread!), and luckily enough i was stopped by a pedestrian before i left who pointed the leak out to me.T
The mother of all has to be a squashed by them sump because they thought its a great jacking point... this lead to an oil pickup problem, which subsequently led to a big end gone 5mins after leaving their shop whilst i was going up moss st, testing my to see if my still cracked intercooler was fixed (which you've already figured it wasnt)!
To top it all off, i took the car back and it went up on the hoist, and they found this mysterious crack in the cooler, which they tried to tell me it wasnt there before (even though i only drove the car for 5mins).... If thats not enough, when i told them about the sump, they denied it, even whilst having a squashed pickup in my hand!
This isnt the first story i've heard like that from that hell workshop. Dont say you werent warned about them... they're dodgy as they get, and not worth the money you save by seeing them. Steer clear!
EDIT - they also tried to tell me that they fixed my intercooler leak (which was aparantly pressure tested!), and that the ecu needs to be remapped because it was mapped with a leaking vacuum hose! Its a beyond a joke, and im still rebuilding the engine because of this crap.
Edited by Cool Hand Luke
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
