My GTR is with Gary at the moment being done. Quoted cost is $1070, but I'm going to ask for a discount as I ended up supplying my own cat as well as paying to have it fitted elsewhere.
He must run the place under a couple of different business names, cos the sign at his factory actually has the business name 'Japtralia'. Phone # is 9837 5771.
He has 3 different businesses all next to each other, he runs a spare parts shop, a compliance and Engineering shop (Lena Engineering) and a smash repair shop (Japtralia)
Hey yeah good idea - here's a couple of pics. Looks great in pictures but I think i'm gonna have to give it a respray. I was told it was in excellent condition but it seems to be far from it. That's the risk hey...
Get the paint work looked at first, might just need re-finishing. I did mine as it was pretty dull when I got it, looks a treat now. What are the problems?
i like your car mate....do u mind if i ask how much it cost you so far?
yeah as I said it looks great in pictures, but not so good close up....
It's cost me just over $10k so far.
Sounds like not much, but add on road costs, compliance, insurance, alarm, tyres, and it's around $14k
here's a couple of pics of the crappy paint...
not really on my own topic but here is the old coolant and some seriously fouled HKS plugs I pulled out today. I don't know how the car was even running...
Fark, brown coolant! is that a sign of a rusty radiator or......
Who did you get to import the car for you? was it any of the well known companies?
:cooldance
It was through prestige motorsport BUT it was a yahoo auction car I think - so prestige had no idea of the real condition of it...
So when prestige bids on the car, they never actually go and see the thing in person to verify that its not a complete flood damaged car or whatever?
So by bidding on yahoo you ran the risk of getting a car that was basically a timebomb waiting to waste your money...?
Somehow i thought it was different :confused:
oh believe me - the seller of the car has a big black mark to his name now... but there's basically not much else you can do. The car was transported straight to a shipping yard when I bought it, to await export. I had to buy this car before it could be inspected anyway, and why pay someone to inspect it when you already own it? In the end it just needs some TLC, but it wasn't what I was expecting.
Oh well, heres hoping that you won't have any really big problems with it. Otherwise you will be like me and wishing, for the money spent fixing it you could have just bought a GTR instead. :D
isn't there like 7 days before the auction ended? and if you were that keen on it surely prestige could've organised an engineer to go check it out before the end of bidding so you didn't get a lemon.
yeah my car is with Gary at lena engineering at the moment. Due to finish Wednesday next week
Dropped the car off there this arvo - Gary seemed like an alright bloke. He discussed everything with me and said it will be ready in 5 days...
Saw your grey R32 in there - he showed me the side intrusion bars he'd put in yours - looks like a good job :-)
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
