  • Replies 416
yeh the cracking noise from the glow stick is a glass rod that holds the liquid.... not good.. its really really fine glass too... :D my friend and i cracked it open.. lozzle i think u and i did over from stoves place that day... he he he
I just remember my mouth burning and running round like a idiot pointing at my face
how can u not know glow stick have glass in them?
what breaks when u crack them?
somethings gotta hold the two chemicals apart so the don't react! then break the stick.... and like magic they GLOOOOOOW! oooooo ahhhh
at least i think i'm right! i'm in denial if i'm not hehehe
I thought it was hard plastic...
i jsut accept the fact they glow ..... what makes a glow worms butt glow .... does that have glass in it too?? There should be scientfic studies regarding the relationship between glowworms and glowsticks.
Glow sticks are good examples of the way chemiluminescent reactions occur. Most of them are non-toxic and use only a very small amount of luminol. Here chemicals are mixed when a vile containing an oxidizing agent is broken and combined with the chemiluminescent chemicals. When they combine oxidation occurs and light energy is given off.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
