  • Replies 75
havent heard anything about a PC release but microsoft will probably do what they did with Halo 1 and release the PC version bout 6 months after the Xbox release
yer so every1 goes and buys a damn xbox - ive never even playd one be4.
I got a new computer the other day
1.5gig ram - p4 3.4ghz - 256meg vid - 150gig hdd.
and i got no good games to play :D
waiting 4 halflife2!!!
i got doom3 but meh. i got bored of that after 1/2 hour
https://www.sau.com.au/forums/topic/55467-halo2/page/2/#findComment-1085376
anybody find halo2 WAY WAY too short? my god i got it yesterday (saturday 4pm) and i finished it today (sunday 2pm) just spent only 6 hrs playing and the credits screen shows up
Well u play it too much then,
Ive been playing it for an hour or two every day and im on level 13 or 14 i think
https://www.sau.com.au/forums/topic/55467-halo2/page/2/#findComment-1086394
You should have played it on a harder level if you were proceding too quickly.
This game took too long to come out, so when I got it I wanted it to last. Started on normal but realized it wasnt going to last, so I restarted on heroic. Lasted a week so far and still going...
https://www.sau.com.au/forums/topic/55467-halo2/page/2/#findComment-1087254
Yeh did the same thing, noticed I was going thru a bit fast so on to heroic now :)
https://www.sau.com.au/forums/topic/55467-halo2/page/2/#findComment-1089172
i like how u can pick up the guns from the..cant remember what they are called.. fly around thingies that shoot you with a lazer type thingie..
and the flood looks better too . i like how u see the little spider looking things go into the body :)
https://www.sau.com.au/forums/topic/55467-halo2/page/2/#findComment-1090836
u mean the sentinels with that sentinel beam?
nice gun but drains ammo like water in a sink, absolutely rapes the flood with that compared to other guns
u actually pay attention to small details? maan, i just shoot at anything that aint human, shoot first, ask questions later
https://www.sau.com.au/forums/topic/55467-halo2/page/2/#findComment-1090891
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
