  • Replies 75
Okay, will add you later tonight when I wake up again.
ended up playing for a little bit thismorning when I got home.. just couldnt pass it up heeh.. so i think I added you.. not to sure if i did it correctly lol
https://www.sau.com.au/forums/topic/55467-halo2/page/4/#findComment-1097895
rest assured, ur money is valuable to microsoft, they will drain ur money like there's no tomorrow....halo3 will no doubt round off the halo trilogy...that and xbox2 will b the console that will cater for it....get ready to fork out another 800 bucks for the console and the game.....neva know...halo3 could b the flagship title that comes with xbox2 to boost the sales of their console...either way, life is still good....good so long as bungie still brings us games of this calibre...
https://www.sau.com.au/forums/topic/55467-halo2/page/4/#findComment-1098206
  • 1 month later...
Hey dude.. I dont get how the levels work.. I was level 7 for like 2 weeks.. then went to level 10 in one night?
any idea how you level up ???
and when are you normaly online?? need to have a big team battle :)
https://www.sau.com.au/forums/topic/55467-halo2/page/4/#findComment-1138486
i have the original halo on PC and i enjoyed it and all, but i really don't understand what everybody sees in it, i hear people at school talking about it all the time, and when halo 2 was released it was huge. It just seems overated to me (without being offensive).... what do you guys like about it so much??
https://www.sau.com.au/forums/topic/55467-halo2/page/4/#findComment-1139329
Yeah I don't know what it is, campaign doesn't interest me that much at all.
It's mainly multiplayer, fast paced, lots of action, lots of chances and best of all, your usually ranked up against people that are on your level. So it should be an even contest, unlike when I used to jump on Unreal Tournament on the PC, I'd be playing against punks that had been there for years perfecting their moves.
Have to enjoy the whole headset element aswell, being able to talk to your mates while beginning a game, sitting there defending a base seeing whats going on, knowing what to do etc.
Anyway, I've developed a new strategy- It's the shotgun and rocket or sniper strategy. You camp somewhere outside there base (sniper) and pick off anyone you can thats hanging around outside or on top of the base, anyone on major weapons, rockets, snipers, power swords, or turrets of warthogs. Run in, switch to Shotgun, pump in a heap of grenades, under the cover of smoke run in and pump them in the head with the shotty...With any luck you get a few kills and your out the door with the flag, or setup for anyone coming in with a bomb.
Or the other approach is sniper anyone on top, try and get in through a top access or anywhere that you can see lots of people hiding, rocket, rocket, rocket - go in, shotty, clean up whatevers left over.
I'm still only level 7, fairly dirty about it considering I was nearly level 9 and then I've suddenly dropped... But oh well
https://www.sau.com.au/forums/topic/55467-halo2/page/4/#findComment-1141512
is halo2 on pc or just the x?
YES... Its called TRIBES2!! :wassup:
For all you girls out there playing HALO,
when you really want to see how good you are, try TRIBES2.
You wont learn TRIBES2 as fast as HALO2 but you probably will be ADDICTED by the time you do.
Also the new TRIBES VEANGENCE kicks HALO's butt as well!
https://www.sau.com.au/forums/topic/55467-halo2/page/4/#findComment-1153779
:talk2hand
:P
https://www.sau.com.au/forums/topic/55467-halo2/page/4/#findComment-1167174
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
