15mm is the difference in DIAMETER of the TYRE (you know made of rubber).
The overall diameter of any replacement rim and tyre must not be:
-more than 15mm greater than largest diameter tyre specified by the vehicle manufacturer for that model or vehicle series.
[edit]
so provided that your tyre profile get smaller as your wheels get bigger, you should be able to put 18's on pretty much anything.
http://www.miata.net/garage/tirecalc.html
https://www.sau.com.au/forums/topic/55635-defected/#findComment-1083957
[edit]
i think he is talking about the width of the tyre, not diameter
https://www.sau.com.au/forums/topic/55635-defected/#findComment-1083961
Anyway back to the original point...
It is 1 inch wider than the original rim width which is 6½" so 7½"
As I said, you might be able to pull 9" if you base it on the 8" GT-R wheels, but if you wanna bend the rules, the cops will play that game and win.
https://www.sau.com.au/forums/topic/55635-defected/#findComment-1083968
Apparently Carmate has rear flared guards for an R32...
But yes... In theory 9" could be legal if what people say about GT-R wheels is correct. I mean it is complianced as an R32 Coupé no matter what version it is (as I understand it) so it could be ok.
If the defect is just for bald tyres then you are fine, just get some decent tyres and rock and roll. Pretty much every 200SX has illegal wheels on it anyway.
If you can pick up a cheap set of 350Z touring wheels they are 17x7 front and 17x7½ rear so that could be a good combo. Just need to find some 350Z with 20" chromies and ask about his stockies!
https://www.sau.com.au/forums/topic/55635-defected/#findComment-1084176
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
