This is a follow up to my previous call for help.
Since installing my profec B, I continue to come on to boost much later than I did with a bleed valve.
Has anyone in SA got a Profec B (series 1) boost controller? (private or business)
If I could catch up with you and swap their controller (black unit under the bonnet with 2 vacume lines attached) with mine for 5 minutes and take the car for a spin around the block it would be much appreciated, and help me determine if the fault lies with my unit or the turbo. - (10-15 minute job from start to finish)
I'm getting desperate guys, the car drives well but it takes so long to come on to boost that its not funny. (no feeling of power until 4500-5000 rpm.
https://www.sau.com.au/forums/topic/55861-help-with-profec-b-boost-controller/
Hi Maxx
I have checked for leaks, but havnt found any. It holds its pressure/vacume well, and I have it set to 13psi (no trouble and no spikes).
But wouldnt a leak give me higher boost?
After all a bleed valve is really just a controlled leak device, so is anything a leak should give me more boost (not that the amount of boost is a problem)
My problem is that the boost is comming on much later in the rev range.
Thanks for your thoughts however.
If anyone else has had this problem I am open to your ideas as well.
hey Steve, I had the same problem .... I bought my ProfecB from an Australian guy in Japan called Japandy. Tilbrooks installed it and it did the same thing as yours - would not limit boost it just kept climbing. So I got Japandy to send me another solenoid and it did exactly the same thing. So I got him to send me another head unit and it did EXACTLY the same damn thing!!!! Mark from Tilbrooks had a heap of different people have a look at it, but they all said it was hooked up right. So they sent the 2 head units and 1 solenoid to James at D1 and he said they both worked perfect on the bench, holding and releasing pressure. I gave up, and bought a new Hybrid EBC.
George from GT Autosound was installing my Hybrid, and he said he couldn't get it to work - it would just skyrocket the boost!!! SAME DAMN THING!!! He said, he switched a couple of the wires around, and it works perfect. He said the wiring was mixed up from the factory (wrong colour wires) - and the ProfecB would have worked fine if the wires had been switched around. Not sure if this story helps, but maybe you have the same problem?
Weq
The sharp/soft dial you are talking about is set to 100% sharp - things only get worse if i turn it towards soft.
Thanks for the thought though.
Problem sorted, the boost controller works well and is really easy to set up.
4 Door, have you checked the switch settings on the back of the controller, as greddy show a setting to use if 'overboosting' - perhaps this is how yours is set, which would explain why it takes longer to come on boost.
good in theory anyways:)
Thanks for the loan of the solenoid and controller, :thankyou: I have tried both and the problem still remains. ;)
I have also replaced all of the vacuum hoses, and have now plumbed the control unit into the bow-off vacuum line (to further reduce the length of hose) but the problem still remains. :rofl:
At this stage I will accept help from Japanese Holly men :ghost: , Voodoo priests, Jedi knights ;) or anyone else with similar qualifications
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 馃槀 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
