- 2001 Nissan 200sx S15 SPEC-S
- 6 sp Manual, pewter, only 39,000kms
- Reg : RCX-730
- Price : $31990ono
- Contact : [email protected] or 0400 888 259
39,000kms, inmaculate condition, unmodified S15. Owned by a very fussy owner and very regretful sale. Only as daily driver, no dragging or racing. It has been serviced every 5000kms with Motul Turbo Light and comes with all Nissan Log books. Interior and exterior is very clean. Its always garaged and is accident-free. It does have top of the range Formula-1 tint and a Nokia mobile holder + charger. 9 months rego and 6 month old Bridgestone G3 sport tyres. I appreciate no test pilots or tyre kickers. serious offers only.
https://www.sau.com.au/forums/topic/55893-fs-2001-s15-200sx/
  • 3 weeks later...
  • 1 month later...
