where to get cheap 1/2 cuts in GC or Bris
Hi, sorry if this is rehashing on old posts, but i hope that someone else is wanting to ask the same questions as these!
I'm in need of an RB25DET 1/2 cut auto, and am finding it difficult to avoid getting ripped off. For eg, I rang up a place on the GC asking for the RB25det 1/2 cut they had advertised in a mag for $3300, but then they wanted $4000 over the phone. I reckon this is a rip off considering that VIC & NSW importers are selling em around the $3200 mark (from what i've heard)
Any ideas? Anyone know of any "contacts" that i can get in touch with??
Cheers.
Guest Boxhead
Cheers.
indeed i will be wanting to ask the same question in a while... so people start answering anytime soon :(
Niz180: where's SCS? How do i get in touch with em?
Dave: Yeah but the time you pay for postage u might as well buy local i reckon - plus if it ***s up you can't just take it up the street to get em to have a look.
Also, I need auto cause it's going into an already auto. VL commodore - too much farting around to convert it to manual
Originally posted by dAVE
oops, forgot to say, u may be better of buy engine with loom... then buying an auto box off here. They go for as low as $150 on the forum...
You reckon? I heard to definately go for the half cut, simply cause you've got the extra bits, and wiring/connecting this to that is a lot easier.
How much for just the engine and loom ya reckon, if i was to pick up an auto box from someone here?
I think RMA are no longer. My wife saw there land advertised For Sale/Lease a few weeks ago in the local paper. I drove past there last week and it was empty - not a single car there.
My wife then tried to email them to see if they had moved etc, see if we could get discounts some other how with RMA Club (some club u get free membership with when u buy a car from them - I've never used it) and it came back saying unknow user.
I know that Mr GTR on the gold coast might have one around. He has allways been reasonably priced, but sometimes a little hard to get hold of. You can try him on 07 55735734 or [email protected] ( i think the email is right).
Cheers
Gary
Tried SCS imports, all they had to offer me was an RB25DE auto front cut, not the turbo... but i kinda want the turbo :(
Also tried to call Mr GTR, but no luck... i'll see if i can get him on email.
As for adelaidejap, seems like they've got just about everything - only problem is it's about the same price as it is here, so by the time i ship it up it'll cost too much. Now the problem is trying to FIND the motor I'm looking for in Brisbane or the Coast!!!
Cheers :D
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
