sory guys wherent on for a couple of days , yeh if u want the manifolds u can havem $100, the turbos are off a stock r33 rb26 so if they have ceramic wheels these would be still the same, if your interested just give me a call on the mob might not have time to check
djcano can you send the manifolds via the post c.o.d. from your local post office, to carl dagg 4 cantrell place narre warren south 3805. and i will cover cost of postage?
ok cool contact me on 0401267277 and will take from there
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
