SPECS
Silver (two tone)
1990
CA18DET
Manual
Sunroof (100% no rusts, no leaks)
179,000kms
RWC
MODS
Trust pod filter
T25G turbo (A1 condition, paid $400 for it)
Turbosmart bleed valve
Sheepdog BOV
R33 GTS front brakes (296 x 30mm disks, twin pot)
3" dump pipe
3" cat
3.5" HKS catback (Big but quiet)
3" Blitz boot gauge (Not mounted, let the acquirer decide, I don't want to spoil a nice dash)
SR20DET fuel pump
Sony 45w x 4 CD player w/ remote
VDO 6" splits
VDO 6x9"
Alarm system w/ remote start (Not installed, too busy)
16 x 7.5" Volk Racing forged rims w/ roadworthy Yokohama Advan tyres
15" drift rims w/ roadworthy Bridgestone tyres
Removed front grille (Can be fitted back if requested)
Removed rear spoiler (Can be fitted back if requested)
Raised bonnet (Can be lowered back if requested)
I have a lot of stock parts in my garage. Can be included with car for free if requested.
Exclusive offers to Garage Titan members/potential members:
Free Garage Titan sticker!!! Just kidding
I'll give higher priorities to GT members plus the free sticker, hehehe...
Ballpark price $7000 but will ACCEPT ANY OFFER. Must go in 5 weeks time.
PICS
I dont think it will take 5 weeks to sell, that's a hot price. The CA's go well!
With the mods you've done it should be fast!
SPECS
Silver (two tone)
1990
CA18DET
Manual
179,000kms
RWC
MODS
Trust pod filter
Sheepdog BOV
3" dump pipe
3" cat
SR20DET fuel pump
VDO 6" splits
VDO 6x9"
PICS
  • 4 weeks later...
oops....i seldom check the forum...thanks for both of ur supportive comments ;) much appreciated
anyway the car is sold
http://www.nissansilvia.com/forums/index.p...topic=63850&hl=
thanks to anyone who enquired it....wish everyone a merry christmas
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
