ok pplz, i noticed the other day when i got up my car a bit and took it to 7 grand it hit rev limiter in second before changing into third, and when i slowed down to a stop to turn into a street the car stalled? was this a result of the rev litmiter telling the computer to shut down so not to damage the engine or something else??? any ideas??? has this happened to any1 else, and also on idle sometimes it revs between 650rpm and 900rpm but goes up and down and fells like its going to stall?? thanx
https://www.sau.com.au/forums/topic/56234-rev-limiter-on-r33-gtst/
nah not caused by the rev limit, rb25s love running there :D
I've really needed someone to answer this question too.
Everytime I take it past around 6,000rpm I feel really guilty and bad for my poor baby :P
Are RB25DET's really rev happy? Like Honda VTEEKKKK BROOOO motors?
Try your throttle body.. Sometimes they become clogged and need to be cleaned out.
My car was acting like a spastic and revving like a retard and stalling so they cleaned the throttle body out and it came all good! Could be something as easy as that and a coincidence that it happened when you revved it out
definetly not related to the rev limit..
probably electrical related, such as AFM(i would try cleaning this before trying other things), spark plugs, or maybe a timing problem. also look for air leaks, check all the hoses.
well ive read another forum post in here and it opened up a can of worms! there are so many things to try and fix huh, afm, idle sensor etc etc. im convinced now that alot of skylines have this problem stocl or modded. they stall and play up on idle and deceleration sometimes. its all trial and error i suppose by the looks of it. it hasnt played up much only that once and i got a bit worried that i thrashed it too hard and it did something bad to it, but obviously not, by reading in here about it. so ive figured that step 1 :check and clean all meters and contacts and check hoses for cracks. thats a start i suppose. but i dont think my particular car has anything wrong with it, just that 1 time like it states in other posts, the fuel pump earth could be the problem. anyway thanx for the info pplz. i dunno what id do without this forum! good job guys keep em coming. 85URK
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
