- Exterior/Engine
  • 93,000km's - Condition of car reflects km's (I don't suspect it's been wound back but you can never say for sure)
  • 222kw at the wheels at ~9psi
  • 5sp Manual
  • 650hp HKS Turbo
  • HKS 45mm Wastegate
  • Tuned Length Exhaust Manifold
  • Custom 3.5" Dump Pipe
  • Hi-Flow Cat
  • Dump pipe back 3.5" Exhast
  • HKS Super Powerflow Airfilter on 100mm Inlet Pipe
  • Greddy Profec B Electronic Boost Controller
  • HKS PFC-FCON Fuel Controller (tuned)
  • HKS FCONV Fuel and Ignition Computer (tuned)
  • HKS VPC Air Controller (No need for Air Flow Meter, and tuned)
  • ARC Front Mount Intercooler
  • OS Giken Twin Plate Clutch (replaced Thrust Bearing too)
  • GTR Fuel Pump
  • Cusco Oil Catch Can
  • Potenza Suspension
  • Gold 18" Advan Model 7 Wheels
  • Back - 18" 255/40 90% Michelin Pilot Sport Tyres
  • Front - 18" 235/40 85% Bridgestone Potenza Tyres
  • Timing Belt, all other belts, filters and fluids were changed at 89,000
  • Motul Engine Oil is used and changed every 5000km's along with Oil Filter
  • Redline Lightweight Shockproof Oil is used in the Gearbox which I have changed twice (last change about 3000km's ago)
- Interior/Exterior
  • Factory Electric Sunroof
  • Tinted Windows Darkest Legal F1 Grade Tint
  • Car alarm/4pt immobiliser/keyless entry. Fitted by Mercedes Benz, worth $800+
  • Greddy Electronic Boost Gauge
  • HKS Turbo Timer
  • Omori Electronic Exhaust Temp Gauge
  • Omori Electronic Oil Temp Gauge
  • Omori Electronic Oil Pressure Gauge
  • Nardi Leather Sports Steering Wheel
  • Alpine CVA-1000E TV Headunit
  • Alpine ERA-G100 Graphic Equalizer
  • Alpine TUE-011A TV Tuner
  • Pioneer Front and Rear Speakers
  • Modified Type M Front Bar for increased flow to the Intercooler
  • GTR Side Skirts (I think)
  • Wide GTR Rear Spoiler with working Brake Light
  • All Car Mats
- Other Info
I imported this car from Japan through Prestige Motorsport and had it complianced by Dean at Ultimate Performance Imports and I still have all the paperwork. This car was marked as Grade 4 condition wise but gets marked something else because of the modifications. The car was off the road for 9 months with a blown motor as an injector crapped out and the engine detonated. I had stock ones cleaned and fitted. I pulled out the engine and replaced it with a recently rebuilt RB25 and while that was happening I sent the turbo off to GCG to be assessed, all checked out good. The car was then tuned on the dyno and checked to make sure everything is ok and working properly. The car has been fantastic since.
Selling due to Overseas Commitments
Located in Melbourne Inner East
$24,900 with 11 months rego (In the Trading-Post for $26,000)
Cheers,
Andrew
https://www.sau.com.au/forums/topic/56394-fs-modified-white-1994-r33-gts25t/
Still for sale guys, I've had lots of interest but no-one serious enough to lay down the cash. I've booked my flight over seas on the 17th January. So make me an offer I can't refuse!
Cheers,
Andrew
  • 5 weeks later...
  • 1 month later...
  • 1 month later...
ok... $22,990. Plenty of go fast goodies on it that would set you back a pretty penny if you were to do it from scratch!
I think this is the kind of car that requires the right buyer as it's not ya standard R33 skyline that you'd look at and say "yep, that's pretty good compared to all the others, i'll take it!". So i'm hoping that buyer is on the forums. It's got heaps of potential with just an injector upgrade and that's it, everything else is done to support 300kw+ at the wheels. It's already got 220kw at the wheels at a lazy 9psi. Imagine running 18psi with the extra fuel supply!!! It would be an animal..... plus the car is no good to me in Australia when i'm over in the UK for a fair while.
PM or email me if you're interested.
Andrew
  • 1 month later...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
