Hey guys i have for sale the following all as a package:
- Garrett GT3540 Ball Bearing Turbo - 700hp capable (made in japan)
- Turbosmart 45mm progate (external wastegate)
- 3" dump/front pipe to catalytic converter
- Screamer pipe for the wastegate
- Front custom size air Filter pipe (to suit apexi POD)
- Front housing to cooler pipe
- Braided lines for oil and water
- Microtech LT-8 Computer (inc instruction manual)
ok these all came off an R33 Rb35det, the turbo exhaust manifold has been modified slightly to fit straight onto standard R33 exhaust manifold so no need to buy exhaust manifold, the wastegate has been tapped into the rear housing so no need for manifold.
The pipes included are 3" for back of turbo to cat, the pipe for the air filter and the pipe for the front housing to cooler as this is slighlt different shape to standard.
the air filter pipe was customed to fit apexi POD filter.
the microtech LT-8 is also supplied in excellent condition.
The turbo itself has done 5000kms and is in excellent condition with no oil anywhere. Believe me its got some serious balls and that wastegate will scare the pants of most drivers.
Reason im selling is because i have decided to sell my car and cant sell with it due to RWC etc.
This conversion is all you need for an R33 rb25det, basically bolt on turbo and exhaust, wire in the microtech and go get it tuned.
I am looking for $3000 ono
this is cheap considering the price of the turbo alone
i will take the first best genuine offer so get in quick.
please dont pm me or post here. CALL ME ON MOBILE 0423 214 005
im in melbourne so if you want to have a look or want pictures call me and i will be happy to answer all questions or supply photos.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
