A fellow Skyline enthusiasst and his 2 passengers have died in a car crash in NSW , the main link is in the GENERAL automotive forum
After only recently loosing a friend in a car crash in fremantle , I know what friends and family go through, and I wouldnt wish it on my worst enemy , If anyone from WA knew ....r34 then I am truly sorry.
All I ask, one reformed dick head who used to spead to the rest of you , please please slow down and dont drift on that corner or round about on the way home, becuase chances are youll take yourself out or some other innocent person. you may be able to live with yourself driving recklessly and speeding . you arent the one that suffers, its your parents , sisters , brothers , girlfriends , etc.
SO PLEASE PLEASE PLEASE
take it to the Motorplex
Mark
https://www.sau.com.au/forums/topic/56705-take-care-of-yourselfs-and-others/
miss_petepie,
i think what he's referring to is the ppl in the General Discussion thread.. everyone keeps saying "RIP EVL34" "Shame, what a nice car" "Poor car" or whutever when 3 ppl including a woman who was 7 months pregnant.. i mean.. its a damn car ffs.. some ppl are just too into cars
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
