I've done about 5,000kms since I bought my Skyline, so its about time to do an oil and filter change (previous owner had the car serviced just before I bought it). So I was just wondering what oil and filter people would recommend for the Skyline. I regularly used Mobil 1 synthetic oil and a basic Ryco filter for my old car and thought it did the job well, but I've heard from quite a few people that Motul is the go for Skyline's. Can anyone confirm?
Also, what viscosity oil is best to use?
Thanks for the help.
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/
Not trying to sound rude but there are alot of threads about oil choice and filter choice here already. Try searching!
If you're lazy then I use motul 8100 5/40 with a JIC (j-brand) oil filter. Ryco apperantly are shite - I must admit so far when I used a Ryco for about 200km my fresh motul came out black as the ace of spades. I've been using my JIC one for about 400km and the oil is still golden brown (texture like sun..).
Might be coincidence may not be - the JIC one was more expensive.
PS: I have a sr20 but I'd use the same thing on a RB.
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/#findComment-1099761
Use a Nissan filter. You cant go wrong with them.. I wouldnt trust Ryco. In my experience they are shit.
Motul are a good oil company. Their 8100 series would be ideal for your car and you can easily do 10,000k intervals on those oils.
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/#findComment-1102338
I always used a ryco filter.
Z145A. No problems yet.
You'll find there is much debate wether which oil is better than the other. I dont think there much all that differnce between them (with in reason mobile, motul etc.). If u plane to change it every 5000k's it probably not worth spending big bucks on top line top brand oils.
But If your loaded with cash and money no object than its a differnt story.
I using a Penrite semisynthetic oil Hpr5
5w 40
at the moment. And i dont have any complaints or problems.
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/#findComment-1102477
I use ryco an havent had any dramas. I went to a ryco info night for work, and comparing to other popular filters on the market there either as good or better. I was even under the opinion they were cheap an nasty until I saw all of there research and comparisons...
Noticed a ryco filter on the orange S15 (when i saw it @melb autosalon)with a AWSOME RB26 under the hood thats on the cover of autosalon magazine.....so they cant be that bad
:D
Berin
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/#findComment-1111867
I tend to use a 10w 40w oil.......(RB20det)......i tend to also stick with sem synthetic simply due to the lower cost........NOTE: I service my "normal" car (R32) every 5000klms with general driving, very little thrashing. But service the "drift " car every 2000klms.
I really don't see the need to sepnd double the amount when the oil is coming out looking nearly as good as when it went in.
https://www.sau.com.au/forums/topic/56851-oilfilter-choice/#findComment-1111913
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
