Dunno if this is the right section but here we go anyway.
Last night OzGTR97-02-02(09-01)V(Vii) mentioned what a pain in the arse it is to check you timing cos of all yobits that you have to take off and I said there is a loop up near the firewall that you hook your timing light up to but of course when I went to find it to show him I couldn't.
Well here it is in the pic. It's the blue wire not the yellow one ok.
https://www.sau.com.au/forums/topic/56953-how-to-check-timing-r34/
It would be just as easy to use A Spark plug lead and coil number 1 !!
The whole point of this thread is to save that kind of effort.  It's one wire just sitting there as opposed to taking the valley cover off, unbolting the coils, etc, etc, etc....
The trouble is the pictures is so dark its impossible for some one who has never done timing before to figure out which wire it is !
But apart from that, it’s a good thread. I’m just giving a 2nd way to do the timing as well. Better to have 2 options then one.
Have you had success with those loops?
My Rb20 is great and its loop works fine.
But the Rb25 on the R33 has similar wires exposed in the harness and they don't do anything, just sent the timing light crazy.
We tried heaps of different timing lights and the dyno bloke warned us we'd have to remove the plug cover and get at the plug harness. He was right.
The blue loop wire at the back works fine for me - using a $50 timing light from Autobarn!
My problem is knowing exactly which marker to use as 15° ??? They are all white markings except for one red one I think at the end - right hand side...are the markers in 5° increments?
Yes they are 5 degree increments .
Some timing lights will work on the loop some won't .
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
