Howdy All,
Just a bit of info for all fellow Stagea type people. And that is that the fuel pumps on the RS4's aren't the same setup as the ones on the R33's.
I went to change mine today, undid the big black plastic locating ring, pulled the cap up and there was only the fuel gauge sender hanging off of it !!! The pump is mounted to the right/bottom side of the fuel tank. Not like the R33's were the pump is mounted to the big cap thingy :)
Soooo, I could be wrong here, but I would say that we'd have to go external if we want to upgrade the fuel pumps, as getting to the factory one down the bottom of the fuel tank is gunna be close to impossible :(
J
P.S. - Anybody want to buy a Walbro internal for $150 + postage :kick:
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/
Interesting.... And the reason I say that is in the Nismo catalogue the 260RS pump is listed as the same as the BNR32 (not BNCR33). Is the tank different, or????
I was considering the R32 pump in my car as a first choice, but it seems that matters may be slightly complicated.
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1103389
You have to be able to get to the pump to service it. There must be a way. As for the Stagea tank being the same as the R32 tank, my Stagea tank is molded plastic and the R32 tank is fabricated steel.:cheers:
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1103854
Ahh, very good.
Was it difficult getting the factory mount/bracket out ? When I had the big cap off, it looked pretty damn hard to get to the mount/pump to get it out.
I was going to take a photo of it but I was a bit worried about using the flash around the petrol.. lol
J
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1106193
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
