Howdy All,
Just a bit of info for all fellow Stagea type people. And that is that the fuel pumps on the RS4's aren't the same setup as the ones on the R33's.
I went to change mine today, undid the big black plastic locating ring, pulled the cap up and there was only the fuel gauge sender hanging off of it !!! The pump is mounted to the right/bottom side of the fuel tank. Not like the R33's were the pump is mounted to the big cap thingy :)
Soooo, I could be wrong here, but I would say that we'd have to go external if we want to upgrade the fuel pumps, as getting to the factory one down the bottom of the fuel tank is gunna be close to impossible :(
J
P.S. - Anybody want to buy a Walbro internal for $150 + postage :kick:
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/
Interesting.... And the reason I say that is in the Nismo catalogue the 260RS pump is listed as the same as the BNR32 (not BNCR33). Is the tank different, or????
I was considering the R32 pump in my car as a first choice, but it seems that matters may be slightly complicated.
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1103389
You have to be able to get to the pump to service it. There must be a way. As for the Stagea tank being the same as the R32 tank, my Stagea tank is molded plastic and the R32 tank is fabricated steel.:cheers:
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1103854
Ahh, very good.
Was it difficult getting the factory mount/bracket out ? When I had the big cap off, it looked pretty damn hard to get to the mount/pump to get it out.
I was going to take a photo of it but I was a bit worried about using the flash around the petrol.. lol
J
https://www.sau.com.au/forums/topic/57066-stagea-fuel-pump/#findComment-1106193
