I Just Saw New Wrx!!!
HEY ppl!!!
I just saw the NEW WRX the one with the liberty like headlights YEH NON BUG EYE rex on the road!!!
i was going up VICTORIA road WETHERILL PARK where SUBARU is located and I SAW ONE!! i followed him to the end of VICTORIA ROAD!
he just SMILED @ me! :)
ok b4 u guys scream LIAR!
I am not on drugs, i do not take drugs, i am not on medication and i don't need medication!!
HONEST TRUTH!!
i had my digi cam in the right hand and left hand was on the steering wheel, while trying to kepe up with him, he was hitting it :( As we turned sep ways he just looked @ me and smiled :)
i was in a R33 GTST,
Donnie!!
https://www.sau.com.au/forums/topic/5724-i-just-saw-new-wrx/
I got a crappy Kodac one,
it woudn't focus in time, i was trying to get it off my side mirrors, mind you while trying to change gears,
**** was playing games with me as well, braking or accelerating around me,
I reckon....IT WAS HOT!!!!, i love the rear lights more than the front!! :D sik! , front had a bigger longer opening for top mount so it looked, it had no foggies from wat i rememeber, in RALLY bLUE
REGISTERED in NSW! :)
DOnnie
https://www.sau.com.au/forums/topic/5724-i-just-saw-new-wrx/#findComment-86638
Guest neoGT-25
hmmmz... heres my thought on the subject...
only another SUBARU to be riced up... meh... i still am heart broken for all this whole "european styling" shit thats been going on with all the Japanese manufacturers latly... espcualy the V35 ;)
ahwell... so are the days of our lives... byes all :burnout:
https://www.sau.com.au/forums/topic/5724-i-just-saw-new-wrx/#findComment-87867
Guest heavyside
the new rexes look shit...
screw all this roundy, lovey dovey, nice lines fat arse crap. the new one is a bit of an improvment on the last model but seriously. they had it right with the first model. nothing came close cept the skyline which will always rule everything.
what was wrong with seriously hard lines and a killer stance, and "that" front bar? get back to what was right, and dont try and fix something thats not broken.
people just dont get it these days...
skylines all the way...esp the 34..
least someone is doing something right in Japland...
https://www.sau.com.au/forums/topic/5724-i-just-saw-new-wrx/#findComment-88742
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
