hey Ryosuke I have a 16" thermo on my R31 & works a treat
I might be able to get u one cheap but will have to look into it + u pay freight cost.
send me a PM if u want me to check into it (brand new by the way & not hot)
I am using a old mits colt thermo switch for the cut in/out, 85 deg (give/take) 5deg+/- 74 deg +/- 3 deg,
I had a 38mm exhust pipe made up thats 2" long placed in the top hose with the switch/nut welded into the pipe, as the clutch fans on the RB's run a heat clutch in them so there is no way to get a switch in there any other way + plastic tank on the Rad means the copper probe is not the best idea as u can bust the top rad outlet trying to over do the clamp to stop leaks
also the switch is a 1 pin switch so u will need to earth the pipe out so once the switch opens it earths out through the pipe
Hope that helps a little :(
Cheers Mike
ok i ll try and autobarn...pm sent Oz your explaination is abit complicated for me lol
i just had a fmic installed and now the car overheats....tried tightening the belts,removed thermostat,flushin but doesnt help with the engine temps
thats what i think aswell i havent measured it yet but lookin at pics i think it just fits(http://ausrotary.dntinternet.com/forums/vi...pic.php?t=52641)
ive also removed my whole air con setup and left one of the fans which was used for the air con it helps but its noisy and the amount of air is not enough so it must be the fan thats the problem
mazda rx7 88turbo
it started overheating after the whole engine was put back in incl the radiator
it had a fmic installed along with the removal of the air con
tried a number of things such as removal of thermstat,tightening pulley and flushin radiator and waterpump but havent really helped
i spin the clutch fan but it seems to be ok
If the motor has been fully rebuilt they do tend to run a little warmer due to them being tight. Probally not to this degree though.
When you start the car when its cold can you hear the clutch fan (should be louder when cold because the clutch oil runs to the bottom of hub). My point is it should be engaged when you first start the car.
After a couple of minutes it should dis-engage and go quiet. It should then re-engage when the motor comes up to temperature.
If the hub is functioning and your sure of that, it may be one of two problems.
If the radiator was removed and allowed to dry out so to speak from sitting empty while motor was getting worked on. It may have had some internal corrosion/sludge flake off the tanks and block some of the rows effecting cooling capability.
If you reverse flush the radiator, (the opposite way that they water normally runs) you may blow any debre/crap out of the radiator thats causing possible trouble.
If you are sure the radiator is fine as well. The next thing would be to look at the FMIC and how much it is impeding flow to the radiator.
If it is a large bar and plate and the only way to the radiator is through the cooler, my guess is this may be your problem.
I've fitted heap of coolers with never having any negative effects to engine temp but there has always been an alternate way for the radiator to get air flow, not just from through the cooler. (Not familiar with the setup you have so cant comment)
The only other things it could be is faulty water pump (unlikely) excessively retarted timing which causes manifold to glow red hot and overheat motor. (unlikely).
You have already mentioned that the thermastat is ok?
hey ryosuke if its only since the motors been rebuilt as RB30 power said they do run hotter after a rebuild but what was done side seals apex the hole lot with water seal kit??????
I would be sus of the motor build a bit, also has it only started after the cooler was fitted or after the engine was reconed????
AH FORGET I ASKED LOL I AM BLIND
yeah binky I have noticed the same thing with my car it the car idles a lot smoother & also the car runs a lot cooler then with the clutch fan I am running a inline switch in a 38mm diameter pipe thats 2" long in the top hose & it works a treat had to many probs with the copper prob leaking out around the top rad hose & didn't want to try & nip it up more as the RB 's run plastic tank's & was worryed about busting the tank outlet.
ALSO Ryosuke if u do go with a thermo fan KEEP THE FAN SHROUD on the rad just cut it a little so the thermo fan will fit on under it, it means that the fan will pull air through better, by the way sorry about my 1st post I though u had a line :D
lol RB30 power i dont really understand your explaination that much but when the engine was put it and i tried turnin the engine over i heard funny sounds from the clutch fan but now it doesnt make noises nomore...the engine has not been rebuilt as i had comp tested it and it was almost perfect comp
i think this will be my plan....get one of my old radiators service and rebuilt it....if it still overheats i ll go the thermos.....can someone explain to me the push and pull types of thermos?
yeah i want one anyone wanna trade?
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
