Its the leak yes, It happed to me before...
What it is that, where steering arm located it has Plasric/rubber cover is torn at the top.
It possibley make some kind of winding noise if you try to turn the steering wheel.
check your fluid tank and the rubber.plastic sleeve cover on steering arm.
even resiviour is full if there is leak on the top of the steering arm sleeve.
if your power steering resiviour bubble when car is stationary or not(turning). means there is leak some where.... ( my guess would be those one of steering arm rubber/plastic covers.
Run your fingers over them (squizze them) to check for leaks.
also if mechanic is the only option can someone make a recomendation?
Hey, i have the same problem, just yesterday the HICAS sign decieded to pop up, in the past all i had to do was top up the fluid! but not time time :) mine doesnt make any sound thou !! fluid is fine doesnt bubble so im hopeing its just a leak?? should put it up on the ramps go have a look!
I noticed this grinding noise the other day whilst parking my R32 gts.. under the fluid resivouir i notice there's alot of dirty fluid where it looks as its been leaking (i've been topping it up).. i'm putting the car on the hoist tommorow to check the suspension anyway, so while i'm there i'm going to drain the ps fluid and check all the hoses
The sleeve which is called a rack boot does not seal the fluid.
The rack seal stops fluid coming out of the housing. If there is any fluid inside that boot then the seal is broken. The boot only stops dirt from getting inside to where the seal is.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
