Hi,
I have a GTR power FC which will not save it's values. You can change the value eg idle RPM & the Idle revs don't seem to change. Also after you turn off the ignition (& back on) the value you set it to is back to the previous setting.
My car is an R33 GTS4 with RB26DETT, it's running fine from a standard R33 GTR ECU.
Things I have tried:
Checked all power & earth connection to the ECU as per nissan wiring diagram - OK
Tried another PFC with my hand controller in my car - has the same problem
Yet to try:
My PFC in another car
Another Hand Controler with My PFC
My deduction so far is that it is either the car's wiring or the Hand Control...
Can any body help, or know of a good workshop who could help to sort this out.
Thanks in advance.
https://www.sau.com.au/forums/topic/58003-gtr-power-fc-experts-wanted/
Hi,
Checked all power & earth connection to the ECU - OK
Yet to try:
Thanks in advance.
Probabley locked by Excel tuner... find a Datalogit owner and they can unlock it for you... It won't cost over $1000.
Oh, you say two different PFC's do the same thing? Well thats a different story.
Will it accept a change to the ignition or fuel map?
TT
Thanks Tom, I think it was you who suggest before it may be locked.
I took it to croydon & had Jim check it out, he said when it's locked that you cannot even access the fuel map menu etc.
Mine is all there, it just won't save. :(
Hi,
Yet to try:
Thanks in advance.
You have to save the changes, have a look at the Commander Manual it shows you the steps.:)
I'm pretty sure I'm saving the settings as per the manual, Jim from Croydon Autosports also confirmed that the values are not being saved. He blamed the wiring.
Tomorrow I will try swapping HC & PFC into a known working GTR & see what I can work out.
S/N of PFC PFC-RB26-9605-0349
S/N of HC FCC-NT9605-0366
I'm guessing that the "9605" means that they should be matched.
You'll find it is the wiring in the vehicle to the ECU that is the problem....
A couple of the pinouts require permanent power and then there is a shutdown sequence where the ign switch power is shut off to certain pinout and then the ECU then saves settings and turns itself off. Any change in this power down sequence,(different wiring, alarms, immobilisers)wil cause the symptoms you describe.
Similiar to pulling the plug on a windows based PC rather than shutting it down correctly....
cheers.
RPMGTR, looks like you are correct.
I tried my PFC&Commander in a real GTR today, Thanks to NVDAGTR :P , & it worked fine :(
I noted all of the pins on the ECU which had power, now I can test this in my car & hopefully find the variance....
It's strange how the factory ECU works without whatever is different!
LOL... How many times have I heard that before...?
The difference with the stock ECU is that, it doesn't have to save any changes, as it's not programmable.
AFAIK, there is no save function with the commander, it applies the changes as soon as you change any parameter. The changes are saved when the ignition is turned off, which explains your problem.
Is the GTS4 wiring same as the GTR wiring...?
Would I be having this problem if it was???
I was just hoping that if people had heard of this problem or experienced it so many times they could say something like "yes, pin XX needs contant power for the data to be saved".
Hopefully I can sort it on the weekend & post the results here for future reference.
According to this site (click), most of the Nissan ECUs share the same pinouts.
Your problem is that RB26 transplants in an R33 GTS4 is not very common, give SDU a try as well. Different models of skylines are more prominent there.
Good luck on the weekend.
The Weekend has been a success :wassup:
Pin 16 & the ECCS relay power supply turned out to be the culprits
You don't know how long I have been trying to solve this.... very frustrating :)
Attached are my finding for all those who have this problem in the future.
Thanks again to NVDAGTR for letting my try my PFC in his car :)
just had a response from the Datalogit forum from an SR20 punter who had experienced the same problem!!!
Do you have a wiing diagram - or the rest of the one above. I have'nt seen one so clear before.
TT
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
