Hey guys and gals, parts are as follows...
16" Works Equip 3 piece wheels w/tyres (little tread on 3, 1 90% tread). Not sure of offest width i think is 7'. $1000 ono
Series 1 stock spoiler in maroon $50
M-spec sideskirts in maroon $150
Series 1 grille $50
RB25DET AFM $150
Blitz Dual sbcii, not sure of spec, will find out and post later $350
GFB Stealth FX bov. Direct bolt on for R33 pipe. No welding or modifications reqd. $300
All items are in good condition. Wheels need a polish but in good cond. Few scuff marks on sideskirts, would prolly wax out. Prices are negotiable! Ill try and get pics up soon.
Any enquiries please pm or email [email protected]
Cheers,
Steve
https://www.sau.com.au/forums/topic/58702-various-33-parts-fs/
Sorry for the delay guys! Have been really busy as im sure everyone is. Wild i dont khat it would cost you to post to melb. Any idea where to ask? I have not posted something this big interstate before.
Will reply to pms now
Steve
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
