yeah theres definately a few around... there was one i wanted to buy from japan as it had an RB26DETT in it...
i would have to say it would be different but im still looking... will try and confirm.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124044
Here is some info I have on the Cefiros. Some even came with RB25DET goodness. 4WD was RB20DET.
8809 - 9008 - RB20DET 2WD
9008 - unknown - RB20DET 4WD
9206 - unknown - RB25DE 2WD
More Pictures like the one below can be found at http://www.innaloo.net/~jai/cefiro/fast/
JK
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124078
Thanks for the info mate.
Ok, now the question is,..is it possible to fit all the R32 GTR Drivetrain into an A31(RWD) chassis?
From my understanding the A31's front suspension is McPherson type and the GTR is multi-link,which means they have different suspension pick up points hence a different crossmember.
I may be wrong so feel free to correct me.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124111
The AWD ceffies are the floowing:
Nissan Cefiro 2.0 ATESSA Cruise Model released August, 1990
Nissan Cefiro 2.0 ATESSA Cruise Model released August, 1991
Nissan Cefiro 2.0 SE-4 Model release May, 1992
The SE-4's sucky as, wheras the ATESSA Cruise are the puppies you wanna get.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124145
you'll have to replace all the sensors with proper GTR ones, fit some hicas equipment as most ceffies didn't come with hicas (was only an option). other than that, the ATESSA system in the A31 is very similar to the one in the GTS4, not the GTR's ATESSA. net result the car feels bulky and is less maneuvreble than a RWD car, or a GTR.
Novel idea tho.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124217
i'd say its very similar to making a GTS4 into a GTR. in other words, waste of time n money. keep it RWD and make it more fun. If you really need to spend your money that badly on a GTR with 4 doors, buy a 260RS. It runs a similar setup to what a GTR-Spec ATESSA AWD Cefiro will be like, out of the box. SHould end up costing around the same too.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124231
From where I come from(East Malaysia), the A31 is the only car that is still readily available.Hardly if not never, heard of the 260RS..hehehe... Furthermore, I know most of you dudes here use the A31 for drifting but I'd like a sleeper with an RB26 and 4WD in it(straight line beast). As for the 4WD system, I think I'd forget about all the wiring hassle and opt for the Veilside or APEXi torque split controller...unsure how much they cost though.
Speaking about cost, I can keep the labour rates low as I deal with many workshops almost everyday who can give me good deals.Furthermore, I do have my own mini workshop at my backyard(my dad's also an enthusiast).
If I see a huge possibility of converting the A31 into an RB26DETT/4WD beast, I'll set aside some $$ for it to happen sometime soon. What's holding me back is the modifications to the chassis that is needed to fit the gearbox/ATTESSA system(wider) as well as the front suspension and front subframe/crossmember to clear the moving parts..
FYI, the A31's price over here stays at around AUD 15k. How much is it over there?
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124271
hehe I'm supposed to be in malaysia right now holidayin in KL... anyways... the cefiros in KL are all the RB24S carby versions arent they? I think I saw a few N/A RB20 ones but most of the souped up ones had 1JZ's in them. The Malay ceffies are a bit different to the Jap ones in that the brakes and suspension are a lil different.
An A31 landed and registered in australia can cost anywhere between 12kish for a good clean stock or mildly modified automatic (like the one my dad drives), about 9k for a used and abused drift pig, or a purposely built full tuning house car like inark RB26 ceffy (built by Ken Works as a drift "practice car") will cost you in excess of 16k without compliance and registration which should tip it at about 20k all up.
https://www.sau.com.au/forums/topic/58726-na31-cefiro/#findComment-1124292
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
