I have a set of R33 Calipers and rotors that i was planning to use for my brake conversion... they are no longer necessary.
THey are all in good condition... the rotors shouldnt require machining...
One thing to not is that the rotors have also been redrilled to suit S13 stud pattern (4x114.3) so these rotors will fit both 4 and 5 stud nissan vihicles (redrilling cost me $100 and was done professionally).
Looking for $500ish:
2x front rotors (296mm ones)
2x front calipers
2x back calipers
I will also consider a swap with a little cash adjustment for Either R32 or Z32 Calipers and rotors. I only need the fronts.
https://www.sau.com.au/forums/topic/59365-r33gtst-calipers-and-rotors/
would you sell just the front calipers ??? if so can you pm a price please
if someone wants just the disks then sure thing... otherwise i dont want to get stufck with parts. So if you find someone who wants em u are welcome to grab em.
The rear calipers i dont really care about..
