The accounts i was selling have been updated and upgraded.... stupid wow...
http://www.skylinesaustralia.com/forums/Se...89#entry4103289
Sorry for not being around, i was on holiday.
Will be checking in more often =]
  • 5 months later...
  • Replies 416
Posted Images
lol... hit 80 couple of days ago.
I think its ok, seeming as you can gear up in pretty decent pvp epics which only cost honour.
no need for accumulating marks from different BG's ect, or impossible arena ratings.
Btw anyone from Barthilas - Oceanic ?
Main: Palwan - Undead mage
Edited by gcg7861
Thats why its gay, its so easy to get everything epicalised. Pre-BC was the best because if you had epics people would know you worked your ass for em. Only thing I like bout this game now is running old instances , flashing money at nubs and maken em walk from org to senjin and back under the assumption im gonna give em money to do it only for me to run away and twinking.
Tis crap, every1 has epics if they nerd it out... even just badge farming
Game content is too easy and way to many scrubs
+ wow needs to fix the fairness in the game before i even think about downloading patches.
the game mechanics are screwed pretty much
Whow! Now that is a game, i mean the graphics are mad, the sound is excellent and being a MMORPG is just mad aswell.
Does anyone have the game???
Ive been playing wow for like 3years now and i love it. Pre-BC raiding was the best with the 40mans and BC raiding with black temple and all was so much fun. Now with wrath its fun; i mean i have 2 80's (warlock and warrior) although i havnt started raiding yet coz i cbf. still love the game so much though :D
  • 1 month later...
i gave my char a sex change just before i leveled to 80.. lol
i just clocked over 41k honor last night too.. need to get arena rating to get decent gear though
Ally Get smashed in arena toy LOL. For epics depends what ya need it for BG go for the Savage or Hatefull gear but most arena items need ratings & these ratings arent that easy to get as you all know. As for Pre Raiding epic gear before you enter the eye Naxx 10 man get you sorted for 25 man nax then ya rdy for 10 man eye. All depending on if its a guild run or not.
I quit WoW recently after clearing all Pre-Ulduar Content and having farmed it for months.
Now just trying to fight the urge to renew, just to pvp because i know i'll play it too much..
I hate you Blizzard!
Anyone else on Saurfang Server?
  • 3 weeks later...
  • 2 months later...
ewwww buying accounts. pity the raid that toon ends up in :)
wow is still good, although ive only played it from half way thru BC, i worked my ass off early on for my epic 80's. hate seeing fresh lvl 80's expecting to raid....
far too adictive though, keeps me from tinkering with the skyrine
mmm just renewed again......... now Alliance Thaurissan, Dreadmaul horde, thinking about moving to Barth or Jubei, anyone got some end game guilds i can steal a spot in? =]
Farming is way to easy, spent my first 3 days back pvping, got 5 pieces + belt / trinket. <-- stupid
My account was hacked and i lost my warlock and warrior :D
So i started a new account 2weeks back now and am levelling a Elemental Tauren Shaman - Nismò - on Thaurissian.
Already level 40 with full blues, 120+ spell power and i PWN.
Cant wait till 58 - the guild will run me thru AQ20 (only need like 3 80's) just so i can get the epic gear to show off even through ill replace it within 10mins in Hellfire....
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
