One of my farthers friends went to japan on a honeymoon and brought back this magazine for me.
It is called Club Skyline #20: tuning and modifying, it is around 160 pages and is in japanese. I will include some pictures. Im not to sure how much I want for it but i know that it was around the equivilant of about $25 australia.
Im open to offers. Anyone interested is welcome to PM me or send me an email at [email protected].
-Andrew
https://www.sau.com.au/forums/topic/60219-fs-magazine-club-skyline/
