Hey guys,
1996 Series 2 R33
White
87000km
5 Speed
Air con works perfectly
NEVER BEEN BOOSTED. Has always run stock boost(6-7psi)....i hardly ever give it some and NEVER EVER go over 2500rpm until the car is warm
BODY
Nismo 400R sideskirts
The spoiler is off atm but the car comes with the spoiler, fitted if u like.
ENGINE
Apexi Power Intake filter
HKS Super Dragger exhaust from Turbo back
BLITZ LM fmic purchased brand new 2 weeks ago(not fitted in pics)
GReddy oil cap
ROLLING
Slotted rotors front and rear
17" BLEST rims with dished rears...mmmmm
235's on the front and 255's on rear with good tread
KYB springs n shocks
Front and rear strut bars
Front brake pads in good condition and recently relinnished
INTERIOR
VDO boost gauge
Razo gear knob
Super bright white headlights bulbs
SOUND
Kenwood double din headnit
Upgraded speakers in the front doors
This car, with just the stock intercooler, pod and full exhaust has made 143.4rwk on...yes...6psi!! on Protek's dyno. It now has the Blitz LM fmic and feels more powerfull and heaps smoother. Still runs stock boost though, around 7psi :flamed:
Oil and oil filter changed every 4000km's, spark plugs every 5000km's and gearbox oil and differential oil every 10000km's. I am not joking either, whenever i get bored i service my car :headspin:
Motul 300V oil just put in last week along with a new oil filter and BCPR6ES spark plugs, brake, diff and gearbox fluid all changed about 6 weeks ago and the front pads were relinished at the same time. The afm was replaced with another low kay series 2 one about 3 m0nths ago.
There is a hairline dint in the drivers door, it is very clean and can be pushed out no worries. There is a bit of wear on the dash just above the middle airvents as when it came over from japan there were four gauges stuck on the dash which have now been removed.
This car was imported by Delrich Lane importers at the beginning of 2003.
Rego till late august
Price is 19,800 <---- Series 2 for this price,,,craaazy
Reason for selling is i'd like to get a cheaper car so i can start to concentrate on career options
Wear on dash
Hairline dint
https://www.sau.com.au/forums/topic/60226-96-series-2-skyline-cheap-must-sell/
Price drop to 19,800...farken crazy arent I? Cmon guys, it's not a dodgey car, easily one of the best lookin r33's in Victoria( u have to see it to understand)
But yeah it just has to go guys,, financial problems
umm with the springs/shocks it sits pretty low...the cooler piping that runs back udnerneath hte cooler sits abit lower than the front bar. but iu have stock springs that come with the car so u could chuck them on if ya want
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
