Hi guys
Im thinkin of selling my R33 GTS-t (rb25det)
Im not in a rush, but willing to let go of this beautyful machine for a deserved price.
Below are the Specs:
Exterior
Candy Pink/Violet in Color
Full Custom Body Kit and i dnt mean full as some people specify it, and then all they got is like a pair of side skirts, or just a front bar)
This inlcuded, custom front (GTR style) bar, side skirts, and veilside rear bar, with the drift style (stealth) boot wing, and gtr front grille, plus rare eyelids, and very very rare NISMO Style bonnet lip (looks sick)
Comes along with GTR badges as well.
Wheels: stock or 19inch (look below on price tag)
Interior: Pretty stock, apart from dash (carbon fibre style), after market gear stick and hand break handle, plus manual look-a-like gear stick, leather boot, and surroundings.
Sound: Clarion speakers all around, plus 12inch sub, and 400watt amp, running by a JVC Double Din Mp3 Player head Unit with remote control.
Engine:
ODO: 99K
Series 1, 93 model RB25DET
Transmission: Auto
Font Mount intercooler
Filter
Boost Controller
BOV (very very loud) The VL Turbo noise
Exhaust: Apexi N1 Cat back
Alarm: One of the best on the market, incl remote enigne start/ or shutdown, turbo timer built in, Live monitoring, with LCD remote, got heapz of features that you can simply enable or disable yourself from out the remote contol (worth $1199)
Turbo Timer (built in the alarm)
GTR Center Gauges (x3)
GReddy Single Pillar Gauge holder plus Blitz Boost Gauge
THIS IS A REAL HEAD TURNER, and i must say bitches love it, this is ideal for a sick mario. heeh lol
All this for Offers Over $20,000 w/o 19s (but stockies) or Offers Over $22,000 With Brand New Wheels and Tyres in 19inch, 2 styles to choose from.
https://www.sau.com.au/forums/topic/60252-r33-chix-magnet/
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
