I'd just like to make an ode to my faithful old r31! which got me down to melb and back without skipping a beat.
:D
It's travelled over 4000km in the last 2 weeks, did about 30,000km last year and its got about 335,000km on the clock, and still going strong. Did two 1400km days in its stride no worries in 30+ degree days.
It may be a box on wheels, it may not have a whole heap of punch these days, but damn they're reliable thrash boxes!
Boy driving around the Police State (Victoria) is painful though!! Driving around there is like getting your scrotem shaved with tweezers! Every second you feel like you're about to get a speeding fine, everybody drives so slow. I think down there I saw in about 2 weeks down there more cops than I've seen in 2 months up here pulling people over. And yet my car still ****ing got broken into for the first time ever after being parked in the street for literally 1 hour!
For godsakes, if they ever try to bring in fixed cameras, stealth cameras and whatever else up here fight every tooth and nail, as it will destroy driving up here forever. It's like you may as well fall asleep at the wheel - driving for enjoyment is dead, and driving just becomes a painful chore. And yet Victorian's still manage to kill themselves very nicely (road toll was up down there about 20 on the year before). It doesn't at all do anything to save lives, so why inflict the pain?
https://www.sau.com.au/forums/topic/60603-champion/
Nice rant Pred :D
Go the 31 though! Good effort... Glad you made it back safely... I've been pondering should I get an old 31 wagon as a basher lately...
It's been a long time since I've been to Victoria and I can't see any reason to go back any time soon by the sounds of it...
Where was the pic taken?
https://www.sau.com.au/forums/topic/60603-champion/#findComment-1149412
geoff: yup, its good to be home!
Thats probably what i'm going to do in a few months to be able to carry my bike, car parts, etc properly, etc.. unfortunately R31 wagons are a bit harder to find.
Can't even remember where I took the photo! was somewhere between the middle of nowhere and the middle of nowhere else along the newell in country NSW. There was a neato looking plane there... let's play "spot the location" !! :D
https://www.sau.com.au/forums/topic/60603-champion/#findComment-1149808
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
