G'day, how is everyone?
Just signed up. I own a black r33 gtst, number plate hicks, maybe you've seen it?
Just wanted to know when theres gonna be another cruise on?
seen you guys last friday night I think, looked like fun.
Also, anyone with an r33 gtst here pulling mid to low 13's.
i've got a 3'' turbo back exaust with dump pipe and hi flow catt,
custom front mount, trust air filter, s-afc and 14 pounds of boost. apparently I should be able to run 13.5ish but I can only get low 14's! only been down to motorplex twice. Think its my lauches,
any tips?
https://www.sau.com.au/forums/topic/6098-cruizing/
yeah I been motorplex twice, first time I had better better times than last wednesday. think it was the weather though.
how should ya launch em?
anyone else's r33 goes click, click, click, click, click, click, click,
from the air con vents when you start her up?
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92118
used to do on mine but I fixed it! but it's pain in the ass I tell ya! you have to take the whole dash a part...
unless you wnat to do that then just put up with it!
if you wanna still want fix it I can give you tips
cheers
Joe
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92153
Get some susupension bushes m8 appaerntly they help with traction off the line quite alot. U get less axle tramp and that kinda stuff so u can really throw it off the line. Do a search for 'pinapples' and u should find something. :D
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92243
Hicks, your black r33 looks incrediably like a r32 to me. Maybe I'm going blind. To run into the 13's you need a low 60 foot time, around 2.1-2.3, which means you need good off the mark traction. Whiteline make a diff craddle kit, its 4 poly-urethene bushes that adjust the rear craddle for maximum traction. Also a good set of tyres, dunlop f901's or sp9000's will do the trick and depending on your rim size. If you've got a nice set of 17x9" deep dish rims you can stretch some 255/35 or something over them, maybe 235/45. you want something with a fair amount of sidewall for flex when you launch. btw: I've only got a cat back exhaust, electronic boost controller set to 0.8bar, hks pod filter, heavy duty clutch and a set of 225/55 r16 dunlop sp9000's and I ran a 14.11 wednesday night just gone. Rev210 (dave) has got a turbo back exhaust, running around 8-10psi boost and he ran a 13.8!
Rob
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92273
nah, its deffinetly an r33. The only difference on mine is that I have had the rear nissan badge(boot lock) removed and filled over. Some tosser ripped it off!
My rims could be a problem, there 245's but theres not much side wall as the rim size is 19''. Looks good though!
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92277
i think i saw you on leach hwy near risely st a couple of times, the bootlock has been filled, and its still got grey primer right?
I have seen 2 different black R33s there, but i definately saw 'hicks' i could be wrong about the primer though.
Nice car all the same.
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92488
mine does that.. sometimes when i turn the car on it does so and the climate control wont turn on until its all clicked out.. im thinking its the air directional doozies or some crap *shrug*..
if it aint broke.. dont fix it.
Shaun
https://www.sau.com.au/forums/topic/6098-cruizing/#findComment-92491
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
