  • Replies 305
Ok!  Here are the details:
Meet: Thornleigh Maccas
Time: 10:30am for (hopefully) a 11am departure
Destination: WISEMANS FERRY
Lunch: The Heritage pub in Wisemans Ferry. Big brown building - the first pub you pass on the right when you hit Wisemans Ferry.  There are a few cafes and coffee places around as well, for those that want something different.
Here is a list of peeps i think are going:
Thomas
Wylie
Ed R34
Seb
siksII
Shruggz
Gus
Shan
Shaolin
Wilchy
Lanfoh
0288
Aplex
Fly_With_Sky
ecl
Wizard2k
Silver
Patto1234
Igor
Maybes:
igor
Sl!m
Mintie
[[danny]]
Phoebe
Someonestolecc
RIK34RGTT
yay nick!!!!! it'll be good to see ya again!! :D are you bringing dom?? :D
r33.. i haven't posted this cruise on any other forums (snsws not included! :D ).. but as i've said before.. its an open cruise to anyone! even a blue lancer with one black door! :rofl:
yay nick!!!!! it'll be good to see ya again!! :rofl: are you bringing dom?? :D
hahahahah.. and its a green door not a black door, chris has a black door :D
we'll discuss radio channel on the day!
and you don't read do you silv! its in the first post!!! lunch is at the heritage pub... a big brown building on the right as you cruise into wisemans... there are also a few other cafes and eating places.. people can just go wherever they feel like!!
There is a fair bit of parking available, but you might have to walk a little.. sorry!!!
Does a cruise need to be registered with cops or anything? I heard one dude saying that cruises are illegal. I was thinking along the lines of working with the local cops and notify them of the cruises, they like that. But i m sure a lot of people would be opposed to that...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
