'93 R33 Skyline non turbo *$12,500*!:
- White
- two way factory sunroof
- GTR400 front bar (best for r33 IMO)
- Enkei Lightweight racing mags (white)
- Nissan sports steering wheel
- 5spd manual
- aluminium shift
- brand new strut brace
- Kenwood double din head unit
-10cd stacker, 10vcd stacker, TV in glovebox
- Kenwood 200W 6x9's
- dark tint, all skyline elecs etc.
- engine totally stock, never modified
- Genuine 155,000km, def. no wind back
- Heaps of reg. left
- Alarm system inc. remote central locking, 3 point immobiliser, windows up feature
- Absolutely any tests welcome
****Asking $12,500****
HAVE FOUND THE HOUSE I WANT, THIS HAS TO GO!
Will consider all offers over $11,500.
I have owned this car for the last two years (in march), and have bought a gts-t in august 04.
Can't afford to keep the two whales (it's kinda hard to drive em both at once anyway :) ) & buy a house, so need to sell in the next month or so.
Top first car, easy to maintain and looks awesome. Nothing to do.
Either PM me for an inspection or ring 0422 119 066 :)
https://www.sau.com.au/forums/topic/61387-fs-r33-skyline-na/
is that a GTR badge in the grill?
hehe, yeah has since been removed... but the buyer of the car will be given the gtr badge as well as a free bag of rice... :)
but seriously, car is worth looking at if you are in the market for a non turbo.
  • 4 weeks later...
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
