g'day g'day peeps.
my factory boost guage in my 32 gtr isn't working.
can someone tell me if the sender is the little black box mounted to the firewall up high on the drivers side... ? and if so, where does the vaccuum line usually lead to for it... ?? .....or am i way off?
where are people usually t-piecing their vaccuum hoses for aftermarket boost guages in these cars.
cheers
david
https://www.sau.com.au/forums/topic/61534-32-gtr-boost-guage-dramas/
OK i can prolly help with this too. You are right, the black box that has a connector and a small tube running from it is for the stock guage. To run a mechanical aftermarket guage you need to t-piece the inlet pressure line to the intake mannifold. An easier one to t-piece would be the line going to the fuel pres. reg.
Again i hope i have helped.
Deren
Sorry to hijack, but my factory boost guage isn't working as well.
The hose that ran to the little black box on the firewall was cut and the aftermarket boost guage connected to it.
Are there any side effects for disconnecting the black box?
Hey nedb no need to be sorry i feel like im taking over all of djhatton's posts anyway :(
So far as i can tell the only thing that happens when the black box is disconnected, is that the stock gauge wont function. Which prolly wouldnt make much diff to your gauge by the sounds anyway. If you want both the stock and aftermarket gauges to function you need to put a t-piece hose connector into the vacuum signal hose (the one that is now only going to your aftermarket gauge) and they will both operate.
Any other problems i'll try to help,
Deren
hey where does this factory boost sender pipe supposedly lead to? mine's not going to anything and a dig around the plenum isn't finding me much... or am i looking in the wrong places?? i can find plenty of vacuum lines... just don't know where that factory one leads...
where's the best place to run a vacuum hose through the firewall for an aftermarket guage? i ahven't looked yet, but planning on fitting the one i've got lying around in the next few days...
cheers
d
The original vacuum line for the gauge runs to the back of the engine (firewall) and connects to the back of the intake mannifold (not the collector/plenum). Its closer to the block..Just use one of the original sealed holes that are in the firewall..
Godzilla32 - Thanx for the reply.
Also, the wires coming out of the little black box they would be just telling the factory boost guage what boost to show, but would they lead to the ECU as well.
I guess what i'm trying to ask is, does ECU know what boost your running and if so where does the signal come from?
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
