  • Replies 74
114:1 afr's....damn smooth your runnin rich :(....man that sucks, your a little over the limit. Are you going to contest it...i know its pretty hard to get done for that due to the precise instructions on how theyre supposed to test. Such as the open area rule etc....hope it all works out, if not do a josh and change the rego to a different name lmao :D
If it pulled 114db ..
a) there is something funny going on.. and they ****ed up the test procedure..
B) you installed a straight pipe recently and/or jet engine.
Mine old R33 pulled 90db.. and my car wasn't loud, but you could hear it. Every 3db is double the loudness.
nah thats not all that unusual. I remeber when josh had the porsche tested it was up around that and i mean it was loud but not rediculous.
a) I said to the cop that the hand held tests werent accurate and he admitted that. So I take the result with a grain of salt. :D
B) correct, has been for awhile now.
If tested properly under normal conditions I would say it would be less... give or take?
Also, he asked why my rear bar was badly burnt... I had no idea why... exhausts are hot I guess :(
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
