Wanted blow off, adaptor plate, Turbo timer, tyres, more stuff :D
Hey alll
im after basic turbo stuff...
turbo timer - whatever im not fussed its only time
blow off - and r32 adaptor plate would be good
gearnob - anything leather clad :(
nissan centre cap for aftermarket steering wheel
bonnet latch clip thing- the thing that holds the bonnet holderuper down :)
horns - anyone got some beefy horns?
and finally some tyres to fit my stock r32 rims.... with some tread!!!!!!!!!
anyone got some 6" speakers too?
oh and a single din pocket to go under headunit...
lastly some R32 type M brake pads - or can u tell me where to get some cheap?
thanks all
Post here or PM me with what ya got
Ed
I got BOV but in R33 pipes
got trust timer for 170 (Brand New)
Got tyre but have to tell me wat size first.......Normally it will cost you $90 each with 80% rubber, coz they are the tyre come with the cars we imported
Gearnob- I got some, but not leather (from $30 with no brand to $180 nismo) Brand new
BOV= Blow off valve
Yes i know this... what brand i mean....
What brands are the tyres? and are they aus legal?
thanks everyone for the PMs
Ed
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
